Compatibility question about the whole steering column dilemma
Old Apr 22, 2001 | 12:11 PM
Tec21-CamaroLover's Avatar
I need to replace my steering column on my '86 Camaro.
I found an '83 Camaro -> Would the steering column from that one fit right in where mine is supposed to go?
Or is another year closer to a match?
The '83 has a lever beside the lock to release the key, mine does not... SO the columns are not exactly... But I just need to know out of what year camaro do I need to get a new steering column from.
Thanks///
'86 Camaro
2.8 MPFI
AC Delco RapidFire SparkPlugs
Premium Gold Distributor Cap & Rotor
Old Apr 22, 2001 | 12:33 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The wiring for the windshield wipers is in a different configuration. The 82 and 83 are different from the 84-up. I ran into this problem when swapping an 84 Z28 column into my 83SC. It was just a matter of swapping around the wires in one connector to make them work properly.
Pete
Pete's Place
HiOutput Tech Page
83 SC
206+k mile LG4/5-speed
14.935@94.14
Old Apr 22, 2001 | 11:40 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
There lever is for a manual transmission car. I never understood why they put it there though! Other than the wiring issue, it would work. If your wiper switch is good, you could change it, and not have to deal with the wiring issue.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Apr 22, 2001 | 11:55 PM
Vader's Avatar
Tec,
There were more '86 'F' bodies built than any other year. I would think you would have little trouble finding an exact replacement.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
