What could cause low BLM's?
Old Jul 30, 2004 | 03:33 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
The other topic is very informative so I'd figure I'd ask.
My block learn is 108 no matter what. I've reset the ECM and it's still 108.
My integrator get down to 80 at times, especially if the 1000 to 2000 rpm range.
Full throttle w/ no load gives black smoke.
Full throttle under load gives a lot of black smoke.
Any ideas or first places to look at?
Scott
Old Jul 30, 2004 | 03:36 PM
kevinc's Avatar
Car: 1982 Z28
Re: What could cause low BLM's?
Scott
It may be a case of O2 sensor contamination. When the O2 sensor gets "poisoned" with silicon, it reads rich constantly. The ECM pulls out fuel, as in your 108 BLM, while the engine's actually running lean.
That's assuming the car was righteous to begin with, and suddenly started acting up without you having changed anything...not sure what your case is.
Just upgrade to 24# SVO injectors and still running a 305 chip burned for 19# injectors or something?
Old Jul 30, 2004 | 06:04 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
No upgrades at all except for gutting the cats.
I changed my O2 sensor recently but it's still running rich.
I can take it apart and put it back together but when it comes to diagnosing, I don't know where to start.
It idles fine and doesn't seem to miss but you can feel when the integrator drops and subtracts fuel.
Somebody, anybody, point me in a good direction.
Old Jul 31, 2004 | 01:08 AM
onebinky's Avatar
When was the last time you changed your air filters? intake restrictions will cause a rich condition as well.
What is your fuel pressure currently?
Old Jul 31, 2004 | 05:43 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Brand new K&N. New fuel filter. Fuel Pressure is 42 with no loss of pressure when shut down.
Could poor ignition be the cause of this?
Old Jul 31, 2004 | 06:38 PM
onebinky's Avatar
how is it running/idling? If it sounds like it's got a miss, than definately could be ign related.
what is your base timing?
Old Jul 31, 2004 | 10:42 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Idles fine, base timing is 6 deg BTC (stock). If I'm driving steadily along a low gear up to 2000 rpm, the car will buck until I give it more gas. I can't just cruise at a steady rpm unless in forth or fifth.
I don't know what the difference is between cutting out/ missing / surging and that's why I'm at a loss.
I also still don't know why my BLM and integrator are so low.
antman89iroc
36
Jan 31, 2016 08:42 AM
BrianI
Oct 3, 2015 12:57 PM
Damon
Sep 26, 2015 04:29 PM
327IROC85
Sep 23, 2015 12:11 AM
ULTM8Z
Sep 16, 2015 09:15 AM
