Is it possible to change gears from 2.73 to 3.23 posi?
Old Apr 23, 2001 | 08:21 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I am not sure but doesnt GM use different series carriers like a 2, 3, or 4 series? does that mean 2 series = 2.XX gears, 3 series = 3.XX gears, and so on? If so, is it possible to replace the carrier?
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
Old Apr 23, 2001 | 02:23 PM
Guest
Guest
Posts: n/a
Depends on who you wanna buy a gear from. You can always get one from Richmond designed for the 2 series with a 3.23 ratio. I'm not sure that anyone else makes a gear like that. I have also heard of people using spacer rings, but to me thats just another thing to break.
Old Apr 23, 2001 | 02:28 PM
89BlwnRs's Avatar
2 series gear go all the way up to 3.08, over 3.08 they become 3 series, and I don't know where the 4 series starts. Yes you can change the series of the carrier, I did this to my 89 Camaro. I went from a 3.08 (2 series) non-posi, to a 3.73 (3-series) positraction.
Also, if you don't want to make the carrier change too, some companies make 3 series gear ratios that fit 2 series carriers. For example I could buy Richmond 3.73s and have them fit a 2 series carrier.
Jason
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Regal105
Aug 23, 2015 03:45 PM
