Compression Test Results
Old Aug 1, 2004 | 10:38 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Hi,
What is the normal compression results for an L98? I got between 173 & 191 (most were in the 180-185 range) and this is dry, with no oil squirt in the cylinder.
The car burns a LOT of oil and runs like crap below 2500 rpm...it has other issues, but I am trying to narrow down the mechnical issues.
Thanks,
Old Aug 2, 2004 | 04:35 AM
ede's Avatar
ede
numbers don't mean anything. the differance between numbers does. 10% or less is good.
Old Aug 2, 2004 | 07:01 AM
Engine: LS3
Transmission: 6L80E
Within reason...that is true. But I am trying to remember what normal should be...the numbers should be around the area that I got, right?
I mean that if I had gotten numbers in the 120 area, that wouldn't be right?
TIA,
Old Aug 2, 2004 | 07:58 AM
ede's Avatar
ede
if they were all the same 120 is fine
Old Aug 2, 2004 | 12:41 PM
Engine: LS3
Transmission: 6L80E
Really? For an L98? I had thought that 120 range would be low for an L98...based on my searches here on thirdgen...
Old Aug 2, 2004 | 01:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The actual raw number depends on a number of factors; the temperature of the castings, the cam, and lots of other stuff.
I'd say the numbers you have are fairly typical.
Old Aug 2, 2004 | 01:29 PM
Engine: LS3
Transmission: 6L80E
OK...that makes sense...I have built a few engines in my short life, not all rebuilds of my 406 either
But it has been a while since I have done a lot of engine diagnostic work like this...so thanks for the heads up!
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
87v6Bird
Jul 1, 2018 04:12 PM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
