Rapid fire plugs
Old Apr 23, 2001 | 07:29 PM
snoozeyaloose85's Avatar
Rapid fire plugs
Could some tell me the difference between rapidfire spark plugs. What the numbers mean, my 85 305tpiTA had rapidfire #2 is this correct or should if have #1. Also the emissions sticker says .045 but on the radiator support it says it was changed to .035 so what the heck is it. Thanks
Old Apr 23, 2001 | 08:12 PM
Vader's Avatar
Snooze,
'85 & '86 305 plug gaps are 0.035" from the factory. I believe that '87 and later (with the separate ignition coil) have a wider 0.045" standard gap.
The Rapidfire plugs are numbered by size, sealing configuration, and nose extension. The nuber listed for your heads should be the correct one to use. I'm told that they all have basically the same heat range.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 24, 2001 | 12:53 PM
Thanks I guess I'll just use the #2 rapid fires
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
Jlanz55
Sep 9, 2015 09:09 AM
greenyone
Sep 2, 2015 03:39 PM
