400 Cracked cylinder
Old Aug 6, 2004 | 03:49 AM
BowtieDriver2's Avatar
Car: '01 sonoma & '91 camaro
My 406 cracked a cylinder. The crack is fairly visible but I have a feeling it could be repaired. I called a few machine shops and asked about a sleeve and they said they could weld the cylinder (cracked toward center of bore thru to steam passage) and sleeve the cylinder. Some shops say that will hold fine and some say it will be too weak.
I was thinking of having it welded and sleeved but also doing a half fill of hard blok to strengthen the cylinder(s). I wanted to get the expert opinions from here before I waste time or money. Will be street driven, occasionaly hard, but not strip use. Not a daily driver.
What do you guys think?
Old Aug 6, 2004 | 06:08 AM
ede's Avatar
ede
if you can't find another block, or have a lot of jack tied up in that one i wouldn't worry too much about the sleeve.
Old Aug 8, 2004 | 12:29 PM
littlebagz's Avatar
Car: 89 Z28
Engine: 350 with ads
The sleeve will hold. A friend of mine has a 406 in a 72 chevelle taht reuns 11.00 at 119 MPH. The motor has TWO sleeved cylnders due to a cracked block. He has no poroblems with overheating or performance, and he does not use any blockfiller.
IMO I dont think you have to worry about the sleeve.
Old Aug 8, 2004 | 12:41 PM
Vader's Avatar
Is the crack through to a water jacket, or just the steam hole? Are you positive it doesn't extend through to an adjacent cylinder?
The only block I've ever had to sleeve was a Pontiac 400 V-8, and it worked fine through a boat-load of abuse afterward.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
