Heres my 383 from the machine shop
Old Aug 6, 2004 | 06:13 PM
Spdfrk1990's Avatar
No1 seemed to look in the appearance section so ill post it in here.
zz4 block
ligntened scat crank
forged h beam eagle rods 6.0
KB Pistons
balanced
Old Aug 6, 2004 | 06:22 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Looks nice, a lot like mine except I went with reverse dome pistons, you must be running a pretty good compression ratio with those flat tops or your using big chamber heads.
Old Aug 6, 2004 | 06:24 PM
Spdfrk1990's Avatar
They called for 10.5:1 with 64 cc heads
Old Aug 7, 2004 | 05:56 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I'd call for more like 11:1 with that setup, assuming they took .010 off the deck that seems to be pretty much standard.
Tom
Old Aug 7, 2004 | 06:15 PM
Spdfrk1990's Avatar
Yeh i did have it decked but i dunno how much he took off. If i do have to run race gas o well i dont drive it much.
Old Aug 7, 2004 | 06:22 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Well I set my stroker up for 10.15:1 with aluminum heads and wish that I would have run more like 11.5:1 At one point, I was running 56 degrees of max timing on 93 octane with no knock. I wasn't comfortable with that kinda timing so I brought it back down to 41 max timing and 89 octane with no knocks, but I would rather run premium gas with higher compression.
Tom
Old Aug 7, 2004 | 06:24 PM
Spdfrk1990's Avatar
I always run premium in my camaro but who knows what your getting in ohio. What kinda lube should i keep on it while its settin. What do yah think about gloss black for the color
Old Aug 7, 2004 | 06:26 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I'd just keep it bagged up. When do you plan on putting it all together?
Old Aug 7, 2004 | 06:27 PM
Spdfrk1990's Avatar
As soon as the money comes in lol if i get a new job then even sooner.
Old Aug 7, 2004 | 06:32 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
What I would try to do first is get the oil pump and pan on there first, then prime the oil system, and then what I usually do is manually turn the motor over by hand and with each cylinder at BDC, use a clean rag or even your fingers to wipe a thin coat of clean oil onto all the cylinder walls.
Tom
Old Aug 7, 2004 | 06:38 PM
Spdfrk1990's Avatar
Thanx ill have to do that i was gonna use this moroso pan
20182 Painted Steel, Deep Sump Pan, 1986 and newer blocks with one piece rear main seal
Pickup No 24350
its made for 82-92 camaros and birds
Old Aug 7, 2004 | 06:52 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Probably the same one that I used, just can't remember the part number
Old Aug 7, 2004 | 06:53 PM
Spdfrk1990's Avatar
Yup that look like it . What color is that block i like it! Well i knows its red n all but what brand and all that.
Old Aug 7, 2004 | 06:55 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Well the shortblock was built by Wheeler Motorsports and they call it "Wheeler Red" and that's all I can tell ya.
Old Aug 7, 2004 | 06:57 PM
Spdfrk1990's Avatar
Damn that sux maybe some1 will chime in b4 long with a similar color. All the ones i find arent a dark enough red. I painted my calipers red and they arent dark enough to me.
Old Aug 8, 2004 | 03:47 PM
MdFormula350's Avatar
383.. drool..........
Old Aug 8, 2004 | 04:29 PM
Spdfrk1990's Avatar
Ok i think i know what im gonna do for the paint. Since my dad has a restoration business i asked him. Urethane Paint suppose to hold up to the heat. So i am gonna jus pick out a dark red at the auto paint store. Use it to respray my cailpers ,block, maybe intake, sway bars.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Magman
Sep 12, 2015 11:55 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
