why won't you run!!??
Old Aug 7, 2004 | 04:11 PM
350andacase's Avatar
Car: 88 camaro
Engine: 305 tbi
OK. Here's the story.
88 camaro, 305, tbi. got the 'ro about 2 months ago. Have been working on it and reading this site ever since. It ran when i bought it, but would hesitate when floored. I drove it home (mostly interstate drive) and about 20 mins in ses light comes on. By the time i got to my driveway, it died, and would only start up for a few seconds at a time only if i feathered the pedal. The codes i got were for egr, too rich and too lean fuel, and electronic spark control.
Here's what's been replaced; O2 sensor, egr valve, plugs, wires, cap and rotor, fuel filter, and pcv valve. My results, nothing. I can't seem to find any vacuum leaks, but hear alot of air around the throttle body. With all vacuum lines hooked up, the car will start for just a second, then die. By experimenting, i've found that if I unhook the vac lines from the front and back of the throttle body, the car will idle if the pedal is feathered but dies without.
I haven't seen any other posts quite like my problem, but would sure appreciate some input.
Old Aug 7, 2004 | 04:14 PM
V12Camaro's Avatar
Car: '89 RS
Engine: 355
Transmission: five speed
Timing Chain.
Old Aug 8, 2004 | 09:53 PM
Car: 88 camaro
Engine: 305 tbi
Thanks V12
Hey V12, obviously your dead on with your response considering how many people read the post and did not reply. I don't know why the thought never crossed my mind. (guess that's why it says "junior member" by my name) Anyhow, hopefully i can change it within the next week. Thanks for the lightning fast reply.
d4
Old Aug 8, 2004 | 10:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Welcome aboard!
While the timing chain may or may not be in bad shape, I would wait to replace it as of now.
Start by checking the fuel pressure and the timing, at both idle and ~3500 RPMs. This checks both the initial static and the total advance timing.
*edit* I just now see where you got your user name. Nice!
Old Aug 9, 2004 | 05:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like fuel delivery to me.
Check your fuel pressure; TBI wants something like 9 psi at idle, 13 psi with no vacuum; if it's low, you can try a fuel pressure regulator (part of th eTBI itself), but more likely it needs a fuel pump.
Old Sep 16, 2004 | 09:31 PM
Car: 88 camaro
Engine: 305 tbi
thanx for the help
Just wanted to post a little follow up. I rigged up my own fuel pressure valve with a schroeder valve and some brass fittings. three trips to the hardware store later, the highest reading i could get was 3, and that was clamping the return line. Anyhow, 3 days spent on and off dropping the tank, and changing the pump. That sucked, and i was working on gravel. Damn i'm bruised up. Anyway, it was the pump. Or maybe just the 2 inches of hose between the pump and the fuel line. It had a hole in it and looked like chewed bubblegum. I think the last guy who changed it used the wrong type of hose. I wasn't about to put the old pump back in after I went through all that to get it out. So I put the new pump in, but used the old hose.
I think were running pretty good now, but the front suspension is next on the "to do" list. Alot of crunch when i turn a hard right slowly. Hopefully i won't have to call out for help on this. I think the first thing i'll check for is that well spoke of crack behind the steering box. (please don't be that!!!)
thanx again for the quick responses. I sure appreciate it.
D4
Old Sep 16, 2004 | 10:19 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Why didn't you replace the hose???!!
camaro11j
Sep 19, 2018 08:49 AM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
