383 VS. 396
Old Apr 26, 2001 | 02:36 AM
92GTA's Avatar
383 VS. 396
I know a 383 is made by using a 400 crank and rods in a 350 block but how is a 396 made using the same 350 block???
Also, which would be a better performer, the 383 or the 396???
www.TransAmGTA.com THE 3rdgen Firebird Site!
1992 GTA (226 made), 1 of only 18 "Dk. Jade Met." 92 GTA's, My Window Sticker, LB9, 700R4 4-Speed, T-Tops, Grey Leather, every available option except G92, J65 and U1A.
Current Mods/Upgrades: 80 Series Dual Outlet Flowmaster, TPIS Air Foil, K&N Air Filter, and Mobil 1.
Future Mods/Upgrades: None but a complete restoration.
Best Track Time: 14.6sec@96.6mph
"If it ain't broke, fix it til it is!"
Webmaster www.TransAmGTA.com
My 3rdGen Firebird Message Board!
[This message has been edited by 92GTA (edited April 26, 2001).]
Old Apr 26, 2001 | 02:59 AM
mtx28's Avatar
a 396 is a 396. its a big block, or as far as i know they all were. in other words, its not 'made' by changing the stroke/bore of another casting.
  • 83 Z28--ttops, 200k miles--very ragged out. sold, thank goodness
  • 74 Z28--slightly modded 383, TH400 tranny, not too quick but fun to drive
Old Apr 26, 2001 | 03:26 AM
Timmys88Z's Avatar
true.
unless you can make some strange combo of a small block that also comes out to "396"
Old Apr 26, 2001 | 03:29 AM
92GTA's Avatar
That's what I thought but I think you can somehow because I've seen them in magazines...
Old Apr 26, 2001 | 04:41 AM
FAST LiFE's Avatar
To achieve 396ci in a small block, you drop a 3.835" crank, vs a 383's 3.75", and over-bore the block to 4.040".
N/A 406, TPIS Miniram, 58mm TB, 30lbs injectors, Custom Ground Elgin Cam, Ported TFS heads, SLP 1-3/4", & DFI computer.
11.70@117mph
Old Apr 26, 2001 | 06:06 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Actually, it's a .030" over 350 block with a 3.875" crank. The advantages are a little more torque at a slightly lower rpm. The disadvantages is cost due to extra machining for the clearancing of the crank, and the cost of the parts due to their "less than common" usage.
A 383 can be built very cheaply due to the proliferation of cheap parts for this combo. You have to ask yourself is the 13 extra cubic inches worth it. For the extra cost, it would be worthwhile to compare the cost of getting a 400 core and rebuilding it. Then you will get an even further 10 cubic inches (406 vs 396).
Old Apr 26, 2001 | 06:52 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
From what I've seen, 396 is getting to be a popular upgrade to the LT1 motor. The number is just famous in Chevy engine history more than anything. And of course, theres no replacement for displacement?
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Apr 26, 2001 | 07:15 AM
Box of Rocks's Avatar
Birdman,
As is normal, listen to Glenn. I have researched the 396 SBC motor and found it to be cost prohibitive. The only way to make one is with a 4340 steel crank, 4340 rods, extra machine work, and some serious cross-bolted main caps. ( Read $$$ )
The big swing of the rods necessitates the mods, and will still deliver "only" 396 cubes.
Like the man said, build a 406 starting with a 400 block, and YOU can decide how much 4340 stuff to buy.
A cast steel crank with 4130 rods in a 406 will be good to 6000 RPM / 500 HP and cost $2,000 less than the super good stuff plus extras the 396 would cost you.
Of course, you could go all 4340 in a 406, spin it to 7,000 RPM/ 600 HP and have a blast in a 2,800 lb. car.
(Just be patient boys, the chef is in the kitchen)
Good luck - and nice car !
BOR
Old Apr 26, 2001 | 10:31 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
The 396 SB is getting more popular bc that is the practical limit for LT1s. But, they are really not worth the trouble over a 383. I saw a impala ss with a 396, LT4 heads, and a comp cam (probably a CC305) make 377 rwhp. The car ran 12.7 with 4300lbs. But, when you think about it, 380 rwhp is really not that impressive. A 383 can make that pretty easy. You also get into some real lame rod ratios and very small spaces for ring location. The oil control ring often requires a support because the wrist pin is soo high up. Certainly required when using any rod longer than 5.7 inch.
Old Apr 26, 2001 | 10:58 AM
jayman350's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Box of Rocks:
</font>
LOL
Old Apr 26, 2001 | 12:32 PM
92GTA's Avatar
I guess I'll just stick with a 383 then...
Old Apr 26, 2001 | 04:07 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I have to admit. I am more impressed with people take big cubes that produce big horsepower and can get it to plant on the pavement. Unlike the common believe at school (der, i got 430 horses and can do burnouts all day long..). Then again, maybe my way of thinking is just...off...
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
