heads for mild 350
Old Apr 26, 2001 | 05:26 AM
blck80z28's Avatar
heads for mild 350
Hi I am looking for heads that will fit on a 72 350 and still work with my tpi I would like to just use gm parts to save money so is there any heads that will do this, also I will need them to be 67cc heads for it to stay at 10.0:1 compresion. If I have to how would I make the tpi fit the older style head what type of machine work would be needed and also isn't the 72 a 2 piece main seal will I run into problems with this because of mine being a one piece.
Matt
Old Apr 26, 2001 | 07:21 AM
Box of Rocks's Avatar
Black Z,
Edelbrock supposedly has a Vortec manifold that will slide between the excellent Vortec heads and your TPI.
Check Scroggin-Dickey for availability.
General concensus around here is that the Vortec head is the best bang for the buck on TPI motors, especially with some bowl detailing and headers. Good luck.
BOR
Old Apr 26, 2001 | 11:24 AM
Beefy89's Avatar
If you buy Vortec heads you can have them drilled to except your tpi manifold.Before you buy them call some local speed shops and ask them about it.I work with a guy who owns a small shop and he has a jig set up just to drill Vortec heads.
Fast as a shark~~~~~~~~~~~~~~~~~ SAVE NAPSTER!!!
Old Apr 26, 2001 | 06:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Vortec heads = special manifold (drilling will allow it to bolt up, but ports still won't match) + EGR re-plumbing + press-in rocker studs + self-aligning rockers.
For a lot less money (less than fixing the Vortec "problems"), you could get World S/R Torquers that will bolt up, keep your compression up, let your EGR work, have screw-in studs, and not need self-aligning rockers or guide plates. And flow just as well as Vortecs.
Why bother with Vortecs?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny.
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
Reddeath210
Oct 6, 2015 08:20 AM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
