Mystery engine rebuild help needed
Old Aug 10, 2004 | 11:34 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Hey guys; the previous owner rebuilt a 1985 305 TPI and put it in my car about a year before I got it. I have the slip from the machine shop, but I don't know what all these part numbers mean. I was wondering, if I post the numbers and what I can find about them, if someone can help me determine what parts are in my engine, so I can see if it's just stock replacement, or better? thanks
pistons-534NP flat top (maybe TRW?)
MS-909 bearings
piston rings-251 X
Melling M-55 oil pump
Here is my big concern. The camshaft number I have is CV-12. I found a site that shows this cam being used in a multitude of engines, like a 75-82 262-267, a 57-80 283-400, a 76-85 305, a 68-73 307, and a 67-86 350. Could it be that the same exact cam was used in all these engines, all these years? Anyone got the specs on the cam, and whether it's worse than, the same, or better than the stock 85 TPI cam?
Thanks all for your time
Kev
Old Aug 10, 2004 | 11:45 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
thats very possible that cam was used in that many engines because you have a non roller type engine.....IIRC
Old Aug 11, 2004 | 06:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pistons http://store.summitracing.com/partde...part=STL-H534P
Oil pump is a stock replacement.
Bearings and rings I don't know offhand; MS-909 looks like "main set" but that's about all I can tell.
The cam is probably a "929" replica {insert gagging sounds here}, just a real basic ordinary useless POS cam. .390"/.410", 194°/204° @.050". It was first used in 283s in the mid 60s, and then all the way through the depths of the smogger era, in every SBC Chevrolet made. For many years in the 70s, it was practically the only cam they used. It is anything but a performance cam.... part of the package, along with dished pistons and heads like the 882 and 993 and 624, that produced such thrilling marvels of engineering as 165 HP 350s and 185 HP 400s.
It's about as bad as the stock TPI cam, except it's not well optimized for TPI.
IROCZ1989
Jan 24, 2016 03:55 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 10, 2015 08:42 AM
hokis
Aug 9, 2015 03:57 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
