Removing plenum -- question
Old Apr 27, 2001 | 12:28 PM
Maverick13's Avatar
Vader has helped me out alot with this EGR project, however I hit a snag. I've got my strut brace off, the THERMAC is off, the throttle body is off, and 7/8 40-Torx bolts are removed from the upper plenum. The problem is with the last bolt (located driver side, middle) -- it's not a Torx bolt. It looks like a standard 10mm bolt with hard plastic tube jutting out of it, thus making my socket set useless. And my standard 10mm box wrench won't fit in the tight space. Any suggestions? Can I just cut that plastic down, so that I can use my socket? I'm not even sure what it does. My guess would be that it's some kind of bracket for the throttle cable that I'm not using.
After I get this last bolt off, the upper plenum should lift right out with a little elbow grease, right? Then it's EGR-swapping city.
Maverick
1989 Formula 350 TPI
5spd Tremec 3550/TKO
several suspension mods
Old Apr 27, 2001 | 02:30 PM
Guest
Guest
Posts: n/a
It is supposed to be a holddown for the throttle cable and cruise cable if you have that.
If its not serving its intended purpose, cut it off. It should just pull off of there though.
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
