Almost Stalls when accelerating
Old Aug 13, 2004 | 08:02 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
1987 Camaro IROC Z-28 355ci with stock rebuilt 700R4
When coming to stoplights or stop signs, and I begin to take off (very conservatively) it will act like it's about to stall between 1000 and 1500RPMs just for a second, then it seems that the computer overcompensates and it jumps forward. After that it accelerates fine. Second gear 1000-1500RPms is normal. Also, while cruising if I let off the gas while in fourth gear the car decelerates more than usual.
Shutting the car off for a couple minutes then starting it up again seems to remove the symptoms of the problem.
My thinking is that it could be the torque converter not unlocking. I hear that you can unplug the 4-prong plug in the transmission and this would preven the TC from locking. Is this true? Can I drive around with the plug unplugged with no problems? Thanks.
Please correct me if my assumptions are incorrect.
Old Aug 13, 2004 | 08:37 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Not sure on the Torque Converter however how long has it been since you replaced the fuel filter. Sometimes a clogued filter can cause a lack of fuel at low RPM and the engine will bog out on you.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
