misting water into engine
Old Apr 28, 2001 | 01:52 PM
4SPEED's Avatar
someone asked if misting water into an engine will help or hurt it. the answer is it will hurt if too much water is used. aircraft used to use water on takeoff for more power when loaded and superchargers blasting away. i am a service advisor in the rv industry and you used to be able to by water injection system to help these under powered monsters when they hit an upgrade, in fact EDLEBROCK used to sell them. i made one out of a windshield washer tank/pump and have used it for 10 years on my 86 ss. the valves and pistons are sparkling. i run 50/50 isoprophl alcohol and water. i trigger the system with a manual switch on the shifter when i get on it. this will enable you to run more advanced timing or lower grade gas if you want to. the trick is to get the proper size jetting. i run cheap gas and higher timing with no ping........anyone else out there that says it doesn't work?
Old Apr 28, 2001 | 02:22 PM
ede's Avatar
ede
https://www.thirdgen.org/messgboard/...ML/008196.html
that should take care of everything you want to know
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 28, 2001 | 06:55 PM
Biochem's Avatar
Car: 2002 SOM z28
Very interesting Ede...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
toronto formula
Nov 10, 2015 06:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
