Distributor questions
Old Apr 28, 2001 | 07:25 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Two questions:
First, like an a$$, I removed most of the sparkplug wires off the distributor without marking where they connect. There is a notch on the cap, is this a reference point for where the plug wires connect by firing order? If not could somebody explain which wires connect to which points?
Second, there appears to be one bolt on the block keeping the distributor from being pulled out (also used to adjust the timing?)...anybody know what type of wrench I could use to get it loose (I think a crow-foot but I'm not sure). Any info would be appreciated.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Apr 28, 2001 | 08:14 PM
ede's Avatar
ede
no the notch just locates the cap to the distributor body. easiest way is to look in a manual and it'll have good pic of distributor and wire locations. if you're removing the distributor anyway best thing to do is set the timing pointer and mark on the dampner to TDC and then set the rotor to #1 and run the wires.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 28, 2001 | 08:16 PM
ede's Avatar
ede
forgot, best to buy a distributor wrench, but a crowsfoot may work too.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
