Traces of oil in SuperRam Plenum
Old Apr 28, 2001 | 03:57 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Im tearing my SuperRam down to fix a fuel leak. When I got the lid off I see what I believe is a little bit of oil spread on areas on the bottom and on the walls of the drivers side plenum near the runner holes. What could this be coming from?
Mark Lock
- 86 IROC-Z - SuperRammed 383/T56
- -= IROC Online =- - The site dedicated to the IROC-Z
Old Apr 28, 2001 | 06:44 PM
Guest
Guest
Posts: n/a
Probably the PCV or breather tube would be my guess. Its not likely that it came up from the intake base or anywhere like that.
Old Apr 28, 2001 | 07:12 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
this normally comes from pcv or breather, but more common just the pcv valve.
Old Apr 29, 2001 | 12:08 AM
poncho9789's Avatar
It is the breather my 97 formula w/lt1 does the same thing. The breather is hooked to the throttle body and the pvc is halfway down the manafold. when I pulled of the manafold the last time after 300 miles you could see oil coming out of the breather hole at the back of the tb
Elephantismo
Feb 13, 2019 12:51 AM
tyeo098
Nov 30, 2015 06:27 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
CatmanFS
Sep 19, 2015 09:00 AM
gta892000
Sep 16, 2015 12:37 AM
