Best Radiator?
Old Apr 28, 2001 | 01:24 AM
gwman's Avatar
Best Radiator?
I am looking to buy a new radiator and would like to know what is the best radiator to use? Copper or Aluminum? And how many rows and what size of rows. What are you guys using? Any help is appreciated.
Old Apr 28, 2001 | 01:51 AM
LottaBallsCamaro's Avatar
I would reccomend a three row alluminum radiator. Alluminum is lighter then brass.
Old Apr 28, 2001 | 07:55 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Not to mention it cools more effectively. I have a 2 row aluminum Griffin radiator and my cars runs about 160* down the road. Also it cost about $180 from Summitt. I would say for that price you can't beat it, but Autozone sells a 3 row aluminum radiator I have heard for $130, but personally I would go w/ the better quality.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Apr 28, 2001 | 01:44 PM
SillyWabbit's Avatar
Car: '91 Formula
Would the same radiator used on a Camaro be used on the Firebird? I would think they do, but I ask this just because of the different front ends of the cars. My radiator filler neck is leaking at the seam where it meets the body of the radiator, so I'm looking to replace it.
Old Apr 28, 2001 | 01:52 PM
jaretz28's Avatar
Hold your horses everyone. Brass radiators by far weigh more than aluminum, BUT they also cool better than aluminum. Ask any radiator repair shop in your city and they will tell you that aluminum doesn't cool as well as brass/copper rads but the weight advantage is worth the swap alone! Get a 3 core aluminum rad, a good workhouse water pump like "Weiand Action Plus Aluminum" and a fan that can pull about 2,600 CFM. ( look at perma-cool fans, you could even get two 14 inch perma-cool fans that pull 2,950 CFM each!!!!!!!!!!!
Old Apr 28, 2001 | 09:32 PM
gwman's Avatar
Im not worried about weight all I want is better cooling. And jaretz28 I already use perma cool fans one 14" and one 10" two 14's wont fit and the kick *** .
Old Apr 28, 2001 | 09:34 PM
gwman's Avatar
Mark A Shields what model Griffin radiator did you get? And did you have to make any mods to get it to fit?
Old Apr 28, 2001 | 09:40 PM
Biochem's Avatar
Car: 2002 SOM z28
I just installed a Griffen radiator which I assume is about 1 1/2" aluminum... rather large. About twice as thick as the stock one was! It won't fit under the frame, but it cools the car, so I am not going to complain.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Apr 29, 2001 | 12:54 AM
gwman's Avatar
biochem what griffin radiator did you get? Model number? Griffin shows model number 6282AE for 82-92 Camaro. Or did you get one of the universal ones?
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
