A comparison of stock L98 Corvette alluminum and Cast iron heads
Old Apr 28, 2001 | 07:31 PM
vortech305's Avatar
I basically know the difference between the two. Just have one question. For an example, an 88' corvette alluminum head(how much does it weigh),88'Cast iron L98 head(how much do they weigh)whats the difference in weight between the two.
Old Apr 28, 2001 | 07:54 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I don't have exact weight measurements for you, but I've heard that a bare casting of an aluminum head weighs 25 lbs. In comparison, a cast head weighs about 50. So you'll save about 50 lbs if you go with aluminum heads. I just got my corvette aluminum heads delivered, and the UPS sticker said the box weighed 46 lbs. I figure that can't be right, seeing as how both heads were fully assembled, valve covers and all.
Old Apr 28, 2001 | 07:57 PM
Guest
Guest
Posts: n/a
Mine were 19 each with everything except valve covers.
Old Apr 29, 2001 | 08:23 AM
Damon's Avatar
I have a set in the basement right now. I threw them on the bathroom scale and they come out at 25 lbs each, assembled with valves, springs, etc. Compare that to a set of cast iron L-98 heads I ALSO have in my basement right now and they are 45 lbs each BARE. So I'd say about a 50lb weight savings off the nose of the car by using the aluminum heads when all's said and done.
Plus, have you even looked at how much better tha port casting and machine work is on these heads versus the cast iron heads? You don't have to port heads for a living to knwo they're gonna flow better.
Old Apr 29, 2001 | 01:07 PM
vortech305's Avatar
Wow, 50lb loss. I thought it was somewhere in the 20 lb area. Is it true that the Alluminum heads tend to flex under alot of pressure(heat). I thought alluminum dissapated heat more quicker than cast iron.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
junkcltr
Aug 2, 2019 11:12 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
