Can i Use my Stock computer chip for my Hooked up 305 TPI?
Old Apr 26, 2001 | 03:15 PM
vortech305's Avatar
As u can see the 88' 305 TPI isnt a stock application. I put alot of work into the motor to bring out the naturally aspirated best in it. I know theres alot more to go,but im through for the mean time. Can i use the stock computer chip for the motor. I do plan on getting an ED Wright custom chip,but i cant as of now since I'm having a problem with money. Im finally about to Start the motor for the first time and ill get the timing sort out, fuel pressure checked out,but JUST FOR THE MEAN TIME CAN I USE THE STOCK CHIP. My mods are in the sig. thanks
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Apr 26, 2001 | 06:21 PM
Vader's Avatar
305,
If you have installed a complete 1988 TPI setup, you should have included a MAF sensor. That should work well enough with your modifications and the stock PROM to allow you to get running at least, and may run you fairly well.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 27, 2001 | 04:15 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
305
How much horse power do you rekon you have with those mods? Do you have any times for the car? I'm interested in what it can do.
Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Old Apr 27, 2001 | 04:24 PM
vortech305's Avatar
Well considering my mods done to the car, im guessing i should have somewhere in the 300-325 hp area. Not really alot, but its enough for a 305. Didnt run the quarter mile yet cause motor is brand new and i havent started it up yet. I have every possible sensor and harness for the 88' TPI. Just concerned if i can use the stock chip since everything is modified. I've been told by many that i should at least do low 13's.
92' camaro
Soon to come!!!
Other car;
Old Apr 28, 2001 | 07:24 PM
vortech305's Avatar
Can i get a second confirm that i can use my STock chip with my application??????????????????????????????????????????????????????????????
92' camaro
Soon to come!!!
Other car;
Old Apr 29, 2001 | 12:56 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
It should get you started and running, and maybe even do pretty good, seeing that it is a MAF setup. Give it a try!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Apr 29, 2001 | 01:08 PM
vortech305's Avatar
I appriciate all your help guys
92' camaro
Soon to come!!!
Other car;
jaridjohn
Jul 8, 2024 03:49 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
