Pinging...?
Old Apr 29, 2001 | 04:58 PM
Little GTA's Avatar
Pinging...?
Why does this happen? What causes it?
I was going to practice take offs and see what was better with my street tires (1100 rpm or idle). Well starts pinging, then stops...while power braking.
BTW:1100rpm is close to breaking my tires loose.
93 octane...hypertech chip...6 degrees initial timing...
Why pinging? need better gas? engine just sucks, or what?
89 GTA Trans Am L98
Wins: 2 Early 90s Stang GT, 4 wheeler, Chevy Malibu
Losses: New Camaro...bastard
Old Apr 29, 2001 | 05:14 PM
speedlvr's Avatar
Usually the timing is too far advanced. Pinging is also called detonation. When timing is too far advanced, the spark prematurely causes the air/fuel mixture in the cylinder to combust which forces the piston back up while it is on it's way down. If you put the timing back to 4*, it will probably stop.
ScrapMaker
Nov 11, 2004 09:24 AM
350turbo411
Apr 20, 2002 09:44 PM
