Fuel Pressure Problem
Old Apr 29, 2001 | 06:16 PM
Jas89TTA's Avatar
OK, On my 87 TPI 350 I turned the key over to prime up the system and it was at 35psi Well I pinched both lines and it went to 40 psi and after 20 min I did not loose pressure, However I took both vise grips off and primed up the system and pinched off the top line (the one that gose to the top of the fuel rail) as soon as I pinched it it went from 35 psi to 40 psi as soon as I took the vise grips off it went down to 15 psi Why? I did the same step to the lower line it started at 35 psi pinched the line and it stayed to 35 psi and when I took the vise grips off it also stayed at 35 psi. Which line on my 87 Is the feed and which is the return? Since I did not loose any pressure with both pinched I'm assuming the injectors are fine. Right? But what about the AFPR could that be the problem? I know I have gas in my oil I just can't figure out why. Any Input. Please help
Old Apr 29, 2001 | 08:55 PM
Jas89TTA's Avatar
Well, It too the runners and plenum off tonight to see if the injectors were leaking well with the plenumen and all out of the way I pulled the rail up and turn the key over to prime up the system it went to about 35 psi and I turned the key off well in less than 20 min it was at 18 psi and there was no fuel leaking from the injectors, So what else could it be? I smell gas in my oil and can't figure out how it's getting in there. I was told by a machine shop that the reason my rings did not seat last time was due to gas in the oil so I'm trying to figure out what's going on before I end up paying for a third rebuild. Any one know another way gas can get into the oil? Desperate for help.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
