Intercooler?
Old Aug 18, 2004 | 05:39 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Intercooler?
Can an intercooler be used on a non forced induction setup? Meaning, will it work with a throttle body or carb alone?
Old Aug 18, 2004 | 05:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What would you cool it with when the air you're taking in is already at ambient temperature?
Old Aug 18, 2004 | 06:35 PM
Car: 88 Camaro
Engine: 310 LG4
Thats what i'm asking, I dont know how they work.
Old Aug 18, 2004 | 07:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Compressing a gas (air, in this case) raises its temperature. An intercooler comes after a compressor (turbocharger, supercharger) to remove some of the heat that was added to the gas as it was compressed. The lowering of the temperature increases its density even more than it was with the pressure increase, meaning more air mass can be stuffed into the cylinder during the intake stroke; and more air mass means more air/fuel mixture can be ignited and burned, thereby making more power.
Since the air of a NA engine is not compressed until it gets into the cylinder, there wouldn't be any way to cool it using ambient air as the heat exchanging fluid before it gets to the cylinder. However, picking up the air to be injested by the engine from the coolest possible source (cool air inlet) accomplishes the same purpose - cooler air is more dense, more mass into the cylinder, more power.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
toronto formula
Nov 10, 2015 06:17 AM
Willie
Jun 13, 2001 12:24 AM
