jumper in a/c connector ?
Old Aug 18, 2004 | 09:24 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i know this is a work around for a bad part but i can;t remember what part is bad. on my a/c compressor the connector has a paperclip in it what is it doing and what part is bad?
some fan relay or something, i forget been a long time since i did this trick. this car came with the paper clip.
Thanks Jeff
Old Aug 18, 2004 | 11:28 PM
1bad406rs's Avatar
Car: 88 Camaro
Engine: 406
Transmission: th350
that paper clip is probably jumping the low pressure cut off switch..not a good thing to be doing..u can burn ur pump up if the pressure is to low because the ac pump isnt getting lubricated.
Old Aug 20, 2004 | 07:37 AM
Vader's Avatar
Most of the old Frigidaire/Harrison six cylinder swash plate compressors had a thermal limiter fuse in the connector near the hub clutch. Perhaps you are thinking of that, since many times jumpers could be found in place of a proper fuse.
The only place to insert a jumper in the R4 compressor systems would be the high or low pressure cutoff switches, or the pressure switch that controls the cooling fan. Of course, you'd only want a jumper in any of those for diagnostic purposes, and not for normal operation.
Old Aug 22, 2004 | 06:47 PM
JeffW's Avatar
Engine: 305 tpi LB9
found it in there when i was cleaning up for painting. i knew it had a diagnostic purpose but some lamo had it in there all the time.
thanks
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
greenyone
Sep 8, 2015 08:41 PM
Ironhead38
Sep 7, 2015 02:26 PM
Glowsock
Sep 6, 2015 06:40 AM
