From non-roller to roller... is it possible?
Old Apr 27, 2001 | 10:31 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Just curious as to whether or not it is possible to convert an older (60's, 70's) 350 to a roller block.
Anyone know how much it would cost/would it be worth it?
Thanks!
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old Apr 27, 2001 | 10:37 AM
Biochem's Avatar
Car: 2002 SOM z28
I am pretty sure you will need a roller cam, camshaft button (which rides along the timing chain cover), a different gear on the HEI (steal vs bronze), and you can use those lifters with the little bar that attaches two of them together instead of using the spider thing in the valley (that sounded odd).
Yes it can be done...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Apr 27, 2001 | 04:12 PM
ede's Avatar
ede
it's been done almost as long as the SBC has been around, just have to use aftermarket parts.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 30, 2001 | 08:25 AM
Mark W. Winning's Avatar
You cannot use a stock roller setup (GM) since you block is non-roller and has not had the material between the lifter bores machined. The allows room for the stock lifter keepers. Comp, and others, make aftermarket roller kits and use a new style keeper that works without machining.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
junkcltr
Aug 2, 2019 11:12 PM
RyanJB
Sep 14, 2015 03:39 PM
palric
Dec 12, 2006 04:09 AM
NEEDforSPEED
Jan 8, 2005 09:37 PM
88355
Apr 29, 2002 06:00 PM
