What size and type of injectors should I use?
Old Aug 19, 2004 | 04:31 PM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
Hi guys
My new motor is almost finished it is a:
383 stroker
86 Corvette aluminum heads..3 angle valve, ported and polished
Ported intake and plenum
SLP runners
either a bbk 52 mm or 58 mm throttlebody (haven't decided)
headers
3.89 gears in a ford 9 inch rear end
2500 stall tourque in a really beefed 750r
I really have ALL the goodies
MSD digital 6 with a 200 shot of N20
What size and type of Injectors do you guys suggest?
I was thinking 24lb Ford Motorsport Injectors?!??!
Thanks guys
Jamie
Old Aug 20, 2004 | 09:02 AM
KustomIroc's Avatar
Engine: 383 Stroker
Please guys need suggestions I would like to order today!
Old Aug 20, 2004 | 10:03 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
30#ers. If you ever plan on updating your intake and heads you will be getting more power and will start to need the larger injectors. I have read about a few guys on here that are pushing the limits on the 30#ers but then again they are in the 450 rwhp range.
Old Aug 20, 2004 | 10:18 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'm using Holley 24# with a Holley 52mm throttle body on my 400+ HP 383, but I'm not using any nitrous. With the extra fuel you need with that I'd probably go with the 30's and a 52mm TB. I doubt the 58mm is needed unless your HP is WAY up there (500-600+), but that's just my opinion. YMMV, of course.
I actually felt my throttle response was better with the 52 than with the 58mm BBK I had on the engine when we pulled it out of the installation bay.
- Ye Old Phat Phart, Vern
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Wvcamaro
Sep 4, 2015 08:38 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
