New Engine Keeps Dying!!!
Old Aug 19, 2004 | 06:55 PM
Steve355RS's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: Rebuilt and bored out L82 from a 1980 Vette
Transmission: TH700R4
Hi everyone, this is my first post here at thirdgen.org. I just wapped out my 305TBI for a carbed 355 from a Corvette, and now it won't stay running. It has a vacuum advance distributor, a red MSD ignition box that hooks up to it, edelbrock carb with electric choke, edelbrock manifold and a mallory fuel pressure regulator. It starts and runs fine in fast (cold) idle but when it goes to kick down to regular idle it dies. I've adjusted the idle, air/fuel mixture, choke, timing, fuel pressure etc.. and it still dies no matter what. It's getting enough fuel and it's at the right pressure, the timing is set correctly, the plug wires are in the right order etc etc etc... It seems like the spark just cuts off when it kicks down because the fuel pump shuts off after it dies. I've been having this problem for the past week and it's the only thing stopping me from driving my car!! Any help is greatly appreciated!!!! Sorry for the long post!
Thanks,
Steve
Old Aug 19, 2004 | 09:04 PM
StealthElephant's Avatar
Car: 87' Iroc
That doesn't sound right. Make sure your fuel pump is getting 12v all the time.
Old Aug 20, 2004 | 02:03 PM
Steve355RS's Avatar
Fuel pump is getting constant 12V, it seems like the spark quits though...
Old Aug 20, 2004 | 02:13 PM
Steve355RS's Avatar
I forgot to mention this started happening out of nowhere one day. Also if I give it any gas it will die, someone said a bad coil. Maybe fuel delivery?? Has a new fuel filter. I need help ASAP I can't even drive my car out of the garage without it dying!!!
Old Aug 20, 2004 | 02:59 PM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
Timing is set right? My blazer would do the same thing with a 454, but I had the timing advanced wayyy too farrr
Old Aug 20, 2004 | 04:50 PM
Steve355RS's Avatar
The book said 12 degrees before TDC so that's where it's at..
Old Aug 20, 2004 | 05:27 PM
Cameron's Avatar
Car: 1985 Z28
Does it idle fine? Maybe you have burned some spark plug wires?
Make sure fuel filter is CLEAN, I have had a brand new fuel filter and ran my blazer on empty for 10 miles looking for a gas station....I ran on fumes and it clogged it all to hell.
Old Aug 20, 2004 | 05:58 PM
Steve355RS's Avatar
It idles great until it kicks down and then it sputters and dies no matter what. Spark plug wires are fine...
Old Aug 21, 2004 | 11:06 PM
Steve355RS's Avatar
Could my box have overheated? It sat on my valve cover when I drove it, maybe the heat messed it up?
Old Aug 22, 2004 | 09:09 PM
Steve355RS's Avatar
Old Aug 23, 2004 | 11:41 AM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
Vacuum leaks will cause this.....high idle can keep it running until you let off the gas and then it can't campensate like an ECM would for the increased amount of air compared to the amount of fuel....
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
