is gasgacinch needed?
Old Aug 20, 2004 | 06:07 AM
JeffC1500TBI's Avatar
edelbrock instructions say to use their part no 9300 gasgacinch when install intake manifold. I'm going to be using gm#10159409 intake gaskets and they have raised edges around the ports. is anything really needed?
thansk
Old Aug 20, 2004 | 06:20 AM
the other thing I noticed with the gm 10159409 is that the rear coolant port is blocked by a metal plate. there's only a small hole it it. is this not restricting coolant flow?
Old Aug 20, 2004 | 07:15 AM
nsimmons's Avatar
i believe most sbc manifolds are blocked at the rear passage, i know my performer is
Old Aug 20, 2004 | 07:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The stock TBI intakes have a huge water jacket under the runners and around the plenum. That is what the small water feed hole is for. It is correct with the plate and small hole.
RBob.
Old Aug 20, 2004 | 11:21 AM
I'm running a 3704 edelbrock performer tbi.. I'll have to check it when I get home..
Old Aug 20, 2004 | 11:36 AM
actually mine are open. right near the one on the ps side there's the connection for the heater core. I wonder if it's ok that there's a very small hole for coolant there. I don't care about the heater. if it's going to make the intake charge cooler then I guess that's a good thing.
Old Aug 20, 2004 | 12:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can use Gasgacinch if you want, but all you really need is a little rtv around the water ports.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
