who can install shifters?? (MICHIGAN)
Old Aug 21, 2004 | 10:15 AM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
I'm thinking of buying the B&M Megashifter for my 86 T/A and I know I wont be able to install it myself because I know I would probably screw it all up. . . What kind of shop could I take it to get it installed??? Anybody live in Michigan that maybe could help me with it??? THANKS AJ
Old Aug 21, 2004 | 11:13 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
That shifter is VERY hard to screw up installing. I installed mine without even having instructions.
All you need to do is unbolt the factory one, pull out the factory cable, bolt the B&M one down in the back bolt holes, line it up, drill 2 new front holes, get some self-tapping screws to bolt it to the front, splice into 4 different wires, cut the factory shifter plate, bolt back up.
I actually just made it sound harder than it actually is. Trust me, if you can operate a drill and can splice wires together you can install it within 2-3 hours taking your time.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
camaro11j
Sep 19, 2018 08:49 AM
Pilotrick50
Sep 2, 2015 12:48 PM
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 13, 2015 07:36 AM
