pontiac parts on a chevy?
Old Aug 21, 2004 | 05:02 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
ok so i bought a pair of heads from a friend. and was wondering will a 86 or so 305 tbi head from a pontiac t/a bolt up to a 92 camaro rs. I plan to do a little port and polish job that is why i am asking.
Old Aug 21, 2004 | 05:50 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Those "pontiac" heads arent really pontiac. That motor is a chevy and so are the heads. The pontiac small block was discontinued years ago.
Old Aug 21, 2004 | 07:06 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Actually, Pontiac never made a 'small block' or 'big block' all of the engines were the same except for the deck height.
Those heads will bolt up as they are standard Chevrolet heads which is actually considered a 'corporate' engine since it was used in so many car manufacturers.
Old Aug 21, 2004 | 07:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If they're '86, good.
If they're TBI, bad. Don't touch them except to use them for a door stop, boat anchor, or for disposal.
They can't be both '86 and TBI.
Old Aug 21, 2004 | 11:10 PM
RICHRAD's Avatar
Actually, Pontiac did build their own head for the sbc for racing purposes. Check the description out at this link http://www.race-cars.com/engsales/ch...75147001ss.htm
Old Aug 21, 2004 | 11:22 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
What is the casting number on the heads?
Old Aug 21, 2004 | 11:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those heads never appeared on a production vehicle, so for all intents and purposes they don't exist.
Old Aug 22, 2004 | 08:30 PM
RICHRAD's Avatar
yeah, neither do TFS, AFR, or DART heads exist either
Old Aug 22, 2004 | 08:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Anybody care to place odds on a set of Pontiac Pro Stock heads being "found" on a L03? or on some random 86 Pontiac 305?
I think it's safe to say, without hesitation reservation or equivocation, your car has regular SBC heads on it, and your friend's heads are also some sort of normal SBC heads. Nothing Pontiac-specific like the ones in question.
Or AFR, Dart, TFS, Brodix, etc. either, for that matter.
If they're 86 heads, they didn't come from a TBI motor since TBI didn't appear in those cars until 88. Which actually, is a good thing; TBI heads being about as anit-performance as you can get, and the early carb/TPI heads (which are the same) a far better casting. And, they will have different valve covers (perimeter-bolt instead of center-bolt) and the center 2 bolt holes will be at a different angle with respect to the intake flange (a nice sensible 90° instead of the later model 72°). So they're not quite a direct bolt-up, but not really a radical change either; just some details.
Old Aug 22, 2004 | 08:57 PM
RICHRAD's Avatar
I won't bet on that, but will bet on these http://www.musclemotorsports.com/eng...num-heads.html
Old Aug 23, 2004 | 12:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If they bolt on to a chevy block, they're a chevy head, regardless who makes them.
Old Aug 23, 2004 | 01:56 AM
2KTA--89Formula's Avatar
Car: 2000 TA & 1989 Formula
Engine: LS1 & a 600lb. paper weight!
Transmission: 4L60 & TH350 w/Manual Valve Body 3400 Stall
92camarors5spd:
The heads came off a 1989 Pontiac Formula Firebird 305 TBI.....next time, just ask! BTW--all 82-92 Camaro/Firebirds share the same Chevy engines <Pontiac has not put out a motor for years>. They both share the same platforms, but they wear different badges w/cosmetic differences...the drive trains are the same.
Old Aug 23, 2004 | 01:32 PM
five7kid's Avatar
If they came off an '89 TBI, then there are two big mistakes: 1) the "bought" part; and 2) taking them home.
Not necessarily in that order.
Drop the "little port and polish job" plans - it just plain isn't worth it on those heads.
Old Aug 23, 2004 | 01:55 PM
He bought them from me for the price I would have gotten as a core charge at a local reman. cylinder head shop. Supposedly, he wanted a set of junk "practice" heads so he could experiment w/porting. Practice does make perfect.......and if he messes up, well, no big loss!
Old Aug 23, 2004 | 10:09 PM
RICHRAD's Avatar
Of course...but it appears Pontiac got in the chevy head game like the rest
jhawkeye
May 25, 2022 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
