have lt1.. and sounds in exhaust.. help..
Old Aug 22, 2004 | 02:34 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I have an 89 TA with a 96LT1 on a 94PCM..
have hedman headers..
when im driving around town and i let off the gas usually with clutch in or going down hill.. (free wheeling i guess..) i'll hear an annoying gurgling and sputter.. sometimes a small back fire.. and if i rev the engine on the decel it will do the same.. doesn't usally do it until it is warm.. looking for suggestions.. I did take a log of the pcm using freescan .. have some numbers.. don't understand them..
did a comp test on the cyl 1-3-5-7 (easy ones) and are 165-165-160-160psi ..
the plugs in all of these were black around the bottom of the threads.. and a slight golden brown but more white on the gnd term.. (i would say lean but not way way lean) ..
going to do other side when i have more time..
also have 1.6:1 rolelr rockers on it...
anyway.. if anyone has suggestions..
thanks.
edit.. its a camaro 2 bolt block with Al heads.
Old Aug 22, 2004 | 04:36 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Mine makes the same noise. Never really bothers me.
Old Aug 22, 2004 | 09:32 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
its driving me crazy.. u rev the thing.. vrooom.. then gargle.. blap pop.. crack..
Old Aug 24, 2004 | 07:01 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
can running lean do anything in that respect?
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
