More A.C. questions...
Old May 1, 2001 | 02:47 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Ok, I know that there have been a lot of AC questions lately, but any help is appreciated...
My AC compressor was leaking a while ago out of a bolt in the top of the compressor, not where it connects to the hoses. Because of that my AC doesn't blow cold anymore. The car has already been converted over to r-134a. What do I have to do besides changing the compressor to get it to work again? Do I have to replace the accumulator if I change it? If I do replace the accumulator do I have to evacuate the system? Can I charge the system on my own and what is needed?
Thanks, Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job.
Old May 1, 2001 | 11:23 PM
SUPER-SPORT-CHEVY's Avatar
Im having problems with ac now also "hop in the boat " I wouldsay that its not nessasary to change the acumulator but if you have the means you might as well do it just to make sure there will be no unforseen problems. The system should be empty already if you have a leak just pull the vale out and let it drain there probably not much in it if any. You can do it yourself its fairly east take less than 10 to charge once its all togather.
Good Luck and "stay Cool "
SSC
[This message has been edited by SUPER-SPORT-CHEVY (edited May 01, 2001).]
ricktaylor
Dec 12, 2002 02:11 PM
jermdm
Sep 30, 2002 03:46 PM
89BlueTA
Feb 17, 2002 11:50 AM
nativ
Aug 7, 2001 11:18 AM
whiterocz
Jun 25, 2001 03:46 PM
