Help! :( Car wont stay on when cold & has rough idle
Old May 2, 2001 | 06:24 PM
Dellz's Avatar
Well here are all my symtoms ..
in the morrning it will take extremly long to warm up and if you let your foot off the gas and let it go below 10x RPMs the engine will stall untill it is warm then the engine will stay on fine .. durring the day i have to give the car about 45 seconds before i can move otherwise it will stall aswll i have kindof a rough idle it will be smoth for about a second then like a jerk and then smoth allso i recently started smelling alot fumes like gassy fumes ..
the car has a full tune up done recently gas filter plugs wires ect.. its a 85 iroc 305 TPI .. can someone plese give me some insite
Old May 2, 2001 | 09:18 PM
Vader's Avatar
Dellz,
Any error codes? It sounds like a mixture control problem, and since it is on cold starts, the oxygen sensor is out of the loop. How is the fuel pressure? Fuel and air filters? TPS voltage? IAC air passages clean? Just some thoughts, but you should scan for codes anyway, since some of them might not set the MIL lamp.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Wade787b
Sep 29, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
Sherpajames
Aug 7, 2015 06:56 PM
