Surging while crusin' around town... wtf?
Old May 2, 2001 | 08:59 PM
Xenodrgn's Avatar
Topic says it all. I was driving my girlfriend home tonight and I noticed that while keeping a steady speed, the car tends to 'surge'... pick up and then let off... under acceleration it's ok though (WOT as well)
I know I have a surging idle problem too (though it gets better when I shift the trans into drive), and that 'marbles in the engine' sound is still there (someone said it was timing chain, I don't think I'm argueing that anymore, but I still have to have it looked at.)... I just did cap, rotor, wires and plugs also.
So, with that info, what do you think the surging is, and what can be done to fix it? Any and all information is greatly appreciated.
1985 Camaro SC - 2.8L, auto. Stock.
Old May 2, 2001 | 09:48 PM
Vader's Avatar
Xeno,
You likely have a fuel delivery problem.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old May 2, 2001 | 10:19 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I had major surging at idle and in park. Lights would go up then dim. After new intake swap and brand new INJECTORS the car idles straight at 500. without any hesitation.
Old May 3, 2001 | 03:11 AM
coach's Avatar
Check out my reply to 89RustangRemover's topic concerning his ECM (it's here in this forum). Go to the last couple of paragraphs of the reply where I talk about throttle position sensor and catalytic converters going bad. That could be the problem that you're having. It may not be because you're car still accelerates.
Old May 3, 2001 | 04:07 AM
ede's Avatar
ede
i'd have to go with vader on this one a nd look towards fuel dilervy, mainly filters or bad fuel pump. there are a number of other things too that might be it, mostly tune up related.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 3, 2001 | 08:53 AM
FastBroker's Avatar
Or a vacuum leak?
Old May 3, 2001 | 03:05 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Fuel delivery, pickup coil going south or a MAF ready for the dumpster seem to be the three things to cause light throttle surging/bucking.
Old May 3, 2001 | 06:11 PM
86TransAmTPI's Avatar
I had a very similiar problem with my 86 Trans Am when i bought it,but my car usually surged at WOT or close to it,under some load,and it was the MAF sensor,the filament wire inside was broken.I dont really remember if i got a check engine light but i think i did and i got the MAF code.I guess it couldnt hurt to look in the MAF snsor and make sure the filament wire is intact.
Al in NJ
Check out My Trans Am:
http://hometown.aol.com/italianknight178/index.html
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
banksGTA
Sep 13, 2015 11:56 AM
DARKmj16
Sep 9, 2015 04:07 PM
