HVAC control vacuum source?
Old Aug 31, 2004 | 08:42 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Not sure if this should go here...
Well In the swap to a stealth ram so long ago I ripped out a bunch of small vacuum lines in and around the engine bay thinking it'd be easy to replace them and that they were all for MAP, EGR and that kind of crap. Well I realized that at least one was for a source for the HVAC controls on the interior. I've got one small tube doing nothing in my engine bay and was wondering if any of you can snap a picture or draw up alittle diagram or hell, toss some sticks my way to show me where to run this tube so I can switch it off of just the defroster vents....
Old Aug 31, 2004 | 08:57 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
IIRC, right side of the plenum, just behind the vacuum port for the fuel pressure regulator.
Old Sep 1, 2004 | 02:57 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I tried hooking it directly to a vacuum port off of the TB and there was WAY TOO much vacuum, nothing worked and there was just a huge sucking noise from the dash... Is there any sort of vacuum regulator?
Old Sep 1, 2004 | 03:15 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Assuming it's a hissing noise you're hearing, it's not too much vacuum. You're hearing a vacuum leak from behind the dash.
Old Sep 1, 2004 | 03:28 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Yeah...from too much vacuum...
Is there some sort of regulator or what?
Old Sep 1, 2004 | 03:32 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
No. Hard to have too much vacuum, when vacuum is what regulates the air diverter flaps and what not. You do not have too much vacuum.
Was it or was it not a hissing noise?
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
Jlanz55
Sep 6, 2015 02:35 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
