Can you flood an engine out with fuel???
Old Sep 3, 2004 | 04:48 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I think I flooded my engine with too much fuel.
The short story is that one of the gaskets for the injectors was torn and was just pouring fuel all over the place. . . like 1/4" deep.
So I cleaned up all the fuel and replaced the gaskets, but now she won't start up. Is it possible that I have too much fuel in the motor now?? And if so, how do I fix it??
Old Sep 3, 2004 | 04:54 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
check your spark plugs ...
Old Sep 3, 2004 | 06:08 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Well I think you would have two options. One, pull the fuse for the fuel pump and keep cranking the engine until the spark plugs burn off all of the fuel. Or, if you push the gas pedal all the way to the floor the ECU will read that as a flooded engine and shut off fuel flow while starting.
Old Sep 3, 2004 | 06:54 PM
Car: 91 RS
Engine: 350 TBI
I did something similiar to that. I just unplugged the injectors while cranking it.
It worked, but I broke another gasket in the process.
Old Sep 3, 2004 | 09:02 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Not quite off. A:F ratio around 20:1
With the amount of fuel you describe you definatly have fouled plugs. You can try cleaning them but considering theyre like $8 for a set. Then put the pedal to the metal and try to start it.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
