Vortec head owners step inside.
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I put the vortec heads on my car and bought some AC plugs that fit the 96 Chevrolet trucks. The problem is that with my heddman headers I can't get a deep well socket or a wrench on some of the plugs because it is 13/16. The wrench won't get a good bite on the plug because the big end of the plug is so close to the head bolts on the bottom.
After I drive around a while I check these plugs and they are loose again.
What plugs are you guys using on these heads with headers? I am wanting some that a 5/8 socket will fit on. I would love part numbers if you know them. Thanks
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I'm using Bosch Platinums for the Vortec truck engines. The Bosch part number on the box is 4205. They are 5/8s and are fairly short. The only plug I can't get the 5/8" plug socket on is number 1 (I have TES headers). It is a bitch to get w/ a wrench as well due to positioning, but all the others are just fine and I can eventually get that jerk #1...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
I have used MR43LTS (the M is for marine plug) in the AC Delco brand. You can probably get them in R43LTS though. They are just regular plugs, I don't like platinum.
-Joseph
ASE Master Automobile Technician
Scoggin-Dickey Chevrolet
1967 Camaro (Vortec Heads, GM ZZ4 intake manifold, ZZ4 roller camshaft)
1992 Firebird (Weiler Vortec Heads, LT4 Hot Cam, GM ZZ4 Intake, Edelbrock 750, eventually will be Ram-Jet)
-Joseph
Do you have the L31 vortec heads? If so I got mine through Scoggin Dickey and the plugs that they told me to use are RS12YC Champions. I haven't had much problem with them, you have to use the plug socket with a end wremch on some of them and #5 cylinder I have to get with a short boxed end wrench. As far as clearence from my headers it's fine, I have full length Headmen headers on it.I hope this will help you! NORT Oh yes they are 5/8 plugs
[This message has been edited by NORT (edited May 07, 2001).]
Well, unless things have changed in the last few months, Accel does not make a shorty header plug with the 3/4" reach (threaded part) that the vortecs need. I use the Bosch 4205 platinum plug (same as RayZ). That is the box #. The actual plug # is HR8DPX, which is a stock heat range replacement plug for '96-'98 trucks. This is the only plug that will work with my Thorley headers as they get too close to the boot at a couple of the tubes, due to the vortec's raised exhaust port. The body (tapered seat to boot end of the plug) on these Bosch's are around 1/8" shorter than most plugs, and equivalent to the Accel shorty plug bodies (even though they don't have one with the 3/4" reach). I never used Bosch's before this, but have had very good luck with them and will continue to use them in other vehicles.
'93 2wd truck
408 sb, vortecs, 454 TBI, Comp Cam, dual exhaust
'93 2wd truck
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Hey guys thanks for the replies. I do have the L31's. I will go to the parts store to see if they have these in stock.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
