Godawful gas mileage :/
Old May 4, 2001 | 06:49 PM
GTA-Force's Avatar
Hi!
I'm getting Godawful gas mileage on my car (in the sig below)...12.8 MPG. Is there anything I can do to improve performance? Here's what I've done to keep gas mileage up:
K&N
92 Octane gasoline
Oil change about 4-5000 miles ago
Cats replaced
Muffler replaced
Any ideas?
Thanks!
1989 Trans Am GTA: 350 TPI, N10 Dual Exhaust
Mods: K&N, Dynomax Super Turbo muffler, 3.5" intermediate pipe, twin Dynomax Super converters, Dunlop Sport 4000 tires.
Old May 4, 2001 | 06:56 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Sounds like one of your sensors has gone and the car is probably running rich. A bad CTS or O2 sensor can contribute to bad mileage. You need to throw it on a scanner and see whats up. I ran a tank of gas out in a 120 mile trip due to bad fuel injectors.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old May 4, 2001 | 07:18 PM
GTA-Force's Avatar
What kind of scanner do you suggest? I found a device that analyzes engine codes (or something like that) when you plug it into the engine, and it's compatible with my car. Or should I take it to a shop and have them analyze it, and ask them for a printout when it's done?
Thanks!
Old May 8, 2001 | 12:23 PM
ImportEater's Avatar
First, but basic -- If you're running a 700R4, make sure that you haven't lost overdrive -- mine had some problems shifting into overdrive a while back and gas mileage will drop off severely.
However, have you noticed any other symptoms? i.e. difficult hot starts, rough idling, power loss, etc.
1985 Trans Am - rough and ready
1976 Corvette Stingray - not so rough, but always ready
Old May 8, 2001 | 03:59 PM
Dan87IROC-Z's Avatar
Go to your local Napa or Autozone or whatever and get a bottle of GB 44K Fuel System Treatment, its $25 but it is well worth it. I ran a bottle through my 84 Z28 and I gained 40 miles per tank! Then, when I bought my 87 IROC, I ran a full bottle through and gained 30 miles per tank!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Glowsock
Sep 11, 2015 11:09 PM
