New heads for my 305. Either Aluminum L98 or something else?
Old May 7, 2001 | 09:52 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm looking to get new heads for my 87 IROC LB9 Auto and was thinking about the aluminum corvette heads. Does anyone know if you can still buy these new? If so do you have a p# and price?
OR....what other heads do you reccomend I get? I want a good difference in power but don't want to spend thousands. Again price and p# if possible.
Thanks for the time
Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Old May 8, 2001 | 04:11 PM
Dan87IROC-Z's Avatar
I don't know if L98 Heads will work on a 305 because of the smaller bore (3.74" to 4.00"). I know that the L98 heads will work on the 4.00" bore or the 4.125" bore, but I don't think that the 1.94"/1.50" valves will fit in the 305s super small bore. I think that the S/R Torquers work on the 305.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old May 8, 2001 | 04:42 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
First, you can run the vette heads on a 305 no problem.
Personally, the best heads my LB9 will ever see are some warmed over stockers. I am not gonna drop $$$ on a set of heads that will be useless on a larger engine. Not that the vette heads are THAT bad, it's just if i was spending the money i'd rather get something better. But you can't get much for a 305 besides those or the SR torquer 305 heads, which again, aren't bad, i just would rather use the money on something better.
305s don't live forever, and thus, my $$$ will wait till something real comes along.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old May 8, 2001 | 06:13 PM
89BlwnRs's Avatar
Well the L98s well definetaly fit, they are part# 12556463 and SDPC2000.com is selling them for $399.50 a piece (assembled). They have the 58 cc chambers, so you'll maintain your compression with them.
Ed is right, the L98s do have small intake runners (which is good for a 305), but they will limit your use on high horsepower, big cube engines. However, GMPP does use the same L98 Vette heads on their ZZ4 crate engine (350 cu. in) that pumps out 355 hp and 405 lb. ft. of torque, so they're plenty big to make power on a 350.
As far as them being compared to the S/R Torquer 305s, they have the same size valves and the S/R Torquers do flow a tad better on the intake, but they can't touch the L98s on the exhaust side.
Also remember if you have EGR, the L98s don't have EGR passages so you'll have to route exhaust from your headers like the Corvettes did and new truck do. This can be done, but it'll probably require a little custom work, but the S/R Torquers will be a bolt-in replacement.
Price and part number for the 87+ S/R Torquer 305s is part# 042750A, and they are $729.90 a pair from Summit or Jegs.
I hope this helps you out, if you have any other questions, just ask,
Jason
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chiknhawk
Aug 23, 2015 05:54 PM
matthew911
Aug 12, 2015 09:38 AM
