Strange sound from the valve covers......
Old Sep 7, 2004 | 12:30 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
Here is the deal. I have been tuning up my engine for the last week and I think I finally got it under control...lol Anyway I have been hearing this sound that I was thinking was spark knock. Well today I was taking my carb spacer out and when I got it back together I fired it up and I could here the noise that I thought was spark knock......Well I put my ear down by the valve cover and I can here is nice and loud from under there. Now keep in mind this is not a tick sound more like a knock sound that varies with RPM's.
What I have for valve train......
Crane Energizer Cam+Lifters 228/228 @ .050 480/480 lift
Speed pro Heat-Treated push rods Stock length
Crane Cams Steel Roller Rockers p/n 11806 1.50 Ratio
Guideplates
Sportsman 2 Heads w/Pioneer spring good to 610 lift, retainers, locks and screw in studs.
Before I go and start tearing this thing down I was hoping for some insight as to what it could be that would make a knock in there..... There is about 5000 miles on the heads. And 1500 miles on the engine.
Old Sep 7, 2004 | 02:40 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Pull the valve cover and see if you see anything out of the ordinary. It could be a variety of things... See if you see anything out of the ordinary... You can also start the car for a few seconds to see if you can pinpoint the sound w/ the VC off. It won't squirt oil for the first few seconds, just long enough to see what the issue is.
Old Sep 7, 2004 | 02:44 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Might be a long shot, but buddy has a BBC with moroso chrome vavle covers and has a few rockers that actually hit the inside of the cover itself and produces a low octive thump thump thump.
If you pull a cover off and no noise that may be the case and require a taller cover or double gasket. Hopefully it's as minor as this.
Cornholio7979
Sep 20, 2018 02:31 AM
db057
Sep 4, 2015 07:57 AM
solocus
Sep 2, 2015 12:14 PM
red90IROCls1
Aug 25, 2015 06:56 AM
db057
Aug 22, 2015 08:17 PM
