Oil Cap Breather Question??!!??
Old May 8, 2001 | 03:49 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I have 2 oil cap breathers and one has the pcv valve hooked to it into the carb., my question concerns the other breather. My brother tells me is should be open uncapped and able to breathe, however my father plugged it off w/ a cap. Who is right on this one, right now I have it plugged off.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old May 8, 2001 | 04:27 PM
84CAMAROHIGHOUTPUT's Avatar
postive crankcase ventilation, the buildup of gases in the engine is not good. i have mine setup with the gromet and rubber tubing going to the base of my open element assembly, kinda how it came stock. not that hard to do either.
Old May 8, 2001 | 08:38 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
that's fine. only one has to go to the carb. all the pressure will vent from that one instead of both.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
406 balanced with 6" Eagle H-beam rods, 10.25:1 JE SRP pistons, Comp 284XE cam; 240/246 @.050, .507/.510, Dart 200cc Ironeagle heads, Victor Jr. intake, Holley 750 vac sec.
12.20 @ 115.25 mph
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
