flywheel question?
Old Sep 9, 2004 | 11:05 PM
NoUseAbleNames's Avatar
flywheel question?
will a t56 lt1 flywheel work with a t 5 on a lt1??? are they 153 teeth?
Old Sep 10, 2004 | 12:08 AM
Dave's 89's Avatar
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
wouldn't work, The T56 uses a different flywheel, bellhousing, and pressure plate. The flywheel is 14'' in diameter and has 168 teeth.
Old Sep 10, 2004 | 07:43 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Only partially correct....
The T-56 flywheel is 12.8", and has 153 teeth. Same size as the one for T-5.
It is different in other respects though.
Old Sep 10, 2004 | 11:07 AM
so definatly wont work then?? what is the size of the one i will need to bolt my t5 to my lt1. i have a old 2 peice one now but im looking for a 1 peice thats all i know. will a clutch off a old 2 piece flywheel fit on a newer one??
thanks
jeff
Old Sep 10, 2004 | 11:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, the T-56 flywheel will definitely not work with a T-5 clutch setup.
The flywheel from a 86-92 305 will bolt right up to the LT1. I'd try to find the lighter weight one, that came on TPI motors; instead of the heavier one from TBIs.
Yes the same clutch will work.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
