strange clunk
Old May 9, 2001 | 06:03 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
strange clunk
When I step on the gas hard around a corner, I hear a clunk in the back left of the car. Could it be the something in the transmission or the springs? Any help would be appreciated
Old May 9, 2001 | 06:12 PM
SpeedStar's Avatar
I have the exact same problem in my 91. Since the rearend is in some sense just floating there. Your probably hearing the driveline hitting the torq arm. I thought it might have been the springs popping, but I checked 'em out and they're fine.
1991 Camaro Z-28 305ci 230hp
1985 Camaro Coupe 331ci 300hp
http://www.geocities.com/speedstar38...Speedstar.html
Old May 9, 2001 | 07:24 PM
AaronK's Avatar
I'm guessing its a broken tranny mount. My did the exact same thing when i first got it and it turned out to be that.
[This message has been edited by AaronK (edited May 09, 2001).]
Old May 10, 2001 | 09:05 AM
84TransAm's Avatar
While you're down there, check the condition of the torque arm mount, it's on the left side of the rear of the transmission. If it's bad, I highly recommend getting a polyeurethane replacement, which is not only stronger, but a much better design than stock .
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Soon: Edlebrock Intake & TES
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
luvofjah
Sep 26, 2015 08:28 PM
BWilcox
Sep 20, 2015 12:19 PM
ynk1121
Sep 12, 2015 12:27 AM
