Walbro Pump ?'s
Old Sep 13, 2004 | 01:17 AM
Hoss50's Avatar
Car: 1985 K5 Blazer
Engine: 350 crate w/TPI MAF
Transmission: 700R4/NP208
Walbro Pump ?'s
I am looking into getting a new external inline fuel pump for my TPI conversion. I have seen some stuff about Walbro pumps.
How is there longevity?
Which pump should I need to provide fuel for a stock TPI on a stockish motor? How many LPH? I won't need a 255 will I? Should I buy a pump with alot higher rating then I need so it won't work as hard to supply my TPI?
Who has the best prices on Walbro pumps? I have seen this place, is there anyone cheaper?
http://www.autoperformanceengineering.com/
Harley
Old Sep 13, 2004 | 02:15 PM
snakeskinner's Avatar
walbro is the #1 intank pump made but I'm not firmiliar with any inlines they make. the majority of any intank pumps you'll buy are made by walbro. even the holley intank are walbro. Kyle
Old Sep 13, 2004 | 02:36 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
If you need extra fuel replace the intake pump IMO. for example a 180 gph pump will only allow that much to go through it, even w/ a 255 booster pump inline. So you may see more pressure, but you are not going to get more fuel through a stock pump that fully open only sees 180 for example...
OH and IMO get the pump from racetronix.com
They have great prices and they are drop in piece.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
