distributor problem
distributor problem
can seem to keep it tight. i'm using a cheap y looking piece and need to get something that works..any suggestions of something i can get at your local auto store before my piece from gm comes in next week?
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
do you mean the distributor clamp keeps comming loose??
or that you cant get to the bolt to tighten it up properly ??
if its the clamp that keeps comming loose then try putting a lock washer on top of the distributor clamp and tighten down the bolt
if its that you cant get to it to tighten it up properly then you need to use a distributor wrench or a crows foot like Vader said ...
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Any chance your bolt is too long? Might try a stud and nut type setup. That's what I use.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You probably have the cheap mr. gasket chrome hold down clamp that I was using until about a week ago... My problem was that with it tightened as much as possible, it didn't apply adequate clamping force to the distributor base. It just doesn't work... Go back to the slotted cast aluminum GM piece and all will be well again...
Originally posted by Kandied91z
i did...thank you.
i did...thank you.
what did you do ?
use a lock washer or buy a different hold down?
however i'm thinking of trying this as it looks better then stock gm.
http://www.jegs.com/cgi-bin/ncommerc...04&prmenbr=361
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Nice. May be too late, but did you happen to check if the one you were having problems with one of those 'stepped' designs that can be intalled only one way? Lots of people have problems with those beign installed upside down. (If I'm dating myself, let it lie
) Supreme Member
) Joined: Jan 2002
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I had the chrome Mr. Gasket/spector(one of those) and it would flatten out. I went back to the GM slotted one also. Dosent look as nice, but have to use what works.
92camaroJoe
Aug 13, 2015 06:07 AM
