weird idle?
Old Sep 13, 2004 | 05:22 PM
TheZ's Avatar
Car: 86 Iroc-Z
Engine: 5.0 TPI
weird idle?
Hi all im new here, my car idles like at 500 rpm when cold in in park, in drive it idles like at 400rpm and then when it gets warm its idling like at 1700 rpm in park and in drive at around 1000 rpm.
thanx for the help in advance.
P.S i have checked very good for vacuum leaks.
Old Sep 13, 2004 | 09:23 PM
kd5boc's Avatar
Car: 92 RS
Sounds like teh Idle Air Control may be getting clogged. On TPI motors they tend to get carboned up at higher mileage. Just take it off and clean it up.
If I remember right, it should be screwed into the drivers side of the throttle body. Or the left. LMAO. Looks like a quarter-sized cylinder with a plug for 4 wires on the end.
Tom
Old Sep 13, 2004 | 10:36 PM
bobsroc's Avatar
Car: 1987 IROCZ
It is under the TPS sensor on passenger side of Throttle body. I would also remove and clean, then adjust. The directions for this are here: https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old Sep 14, 2004 | 12:05 AM
kd5boc's Avatar
Car: 92 RS
gta892000
Aug 11, 2019 11:16 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
