Ignition Timing
Old May 10, 2001 | 11:46 PM
87 IROC 350 TPI's Avatar
Ignition Timing
was going to set the timing on my 90 Iroc 305 TPI I unhooked the computer advance terminal and the timing was set correctly. hooked the connection back up and noticed only a 4 degree advance. That dosen't seem like enough advace to me. The car is low on power. and that's the only possible problem I can discover. Thank's for any help I can get to resolve this problem.
Thank's again
Old May 11, 2001 | 10:19 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
An advance that small may be right for your car while its in idle. Check for any changes while the engine is revved.
Best bet is to get a prom reader to see exactly what your values are and either compare or tweak them to make it better
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
