Draw backs to a stock distributor?
Old Sep 15, 2004 | 11:10 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Should I really be worried about it? It's an HEI (extern. coil) hooked up to a MSD digital 6+. Everything else in the motor and drivetrain have been changed.
Old Sep 15, 2004 | 11:17 AM
ljnowell's Avatar
I have installed stock distributors (recurved of course) with a good coil onto 450 hp motors and had them pull fine all the way to 7k. Some will say it wont, but if it is in good working order its fine.
Old Sep 15, 2004 | 11:35 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Aside from taking a chance the guts are old and worn a stock HEI is plenty of spark for most all motors. The advantage of the MSD type distributors is the ability to easily hook up accesories like 2/3 steps.
As long as the internals are good run it. A new ignition module and cap/rotor would be a basic upgrade and you can have them spun balanced also to ensure proper operation at high rpm. But the last HEI I had set up cost me $250 so by standards of my new stuff I wasted money.
Old Sep 15, 2004 | 01:40 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Your current distributor is probably fine. The only reason one might consider replacing one besides the conversion factor would be a lack of weights or broken peices. The last distributor I had to buy was an accel unit, $130. Either accel decided to make higher quality distributors since the last time I got one or they packaged it wrong cause this one isnt like the one I got a couple years back. Either way there was no perfomance gain over the stock peice but it did come with some nice to have components.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
stalkier
Aug 7, 2015 04:49 AM
