Rear Axle Oil
Old Sep 16, 2004 | 02:27 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Rear Axle Oil
How important is it to change the rear axle oil. I see in the Haynes manual that it is to be changed every 24,000 miles or 2 years. It is something I have never considered doing. I have never heard of anyone changing rear axle oil on cars over here.
Old Sep 16, 2004 | 05:55 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The harder the service, the shorter the interval. A V6 won't be as hard on the gear lube as a V8 would be, daily driving won't be as hard on it as racing would.
Every couple of years isn't a bad idea. Fairly cheap insurance. As long as you don't have an Auburn or Eaton posi unit, synthetic lube will last longer and protect better than petroleum based lube. Make sure it's rated GL-5 (gear lube 5, hypoid gear).
Old Sep 16, 2004 | 08:49 AM
IrocZGrl88's Avatar
Car: 88 Iroc Vert
I changed my gear lube and manual trans fluid a few months ago. Took a whole 20 minutes. I used Valvoline Synthetic gear lube with a bottle of limited slip additive, and synthetic ATF for the trans. When I drained the fluid out of the trans, gear lube came out. I was wondering why my shifts were mushy. ATF is way better IMO.
Old Sep 16, 2004 | 10:34 PM
KnightWarrior's Avatar
Car: 1985 Camaro Z-28
Engine: 305 V-8 4BBL (H) Supercharged
Axle/Gears: 3.42 Eaton Posi
rear axle oil
I like to change mine ever 40,000 miles. It's really easy to do and only takes a few minutes. Just undo the ten bolts on the inspection cover and catch all the dirty oil in a pan. Wipe out the residual crud, put a new gasket on, bolt the cover on ( or clean and paint it if you are finicky like me. )and undo the small allen-key plug on the side. Squirt in a bottle and 1/2 of Mobil 1 gear oil and put the plug back in. You are done!
Old Sep 16, 2004 | 11:29 PM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
Hey IrocZgrl88. Did that "limited slip additive" work at all?
Old Sep 17, 2004 | 03:42 AM
gholian's Avatar
Engine: 2.8 V6
Thanks Knight Warrior, I have one last question. I am a bit concerned about the seal on the inspection cover. Because I live in Ireland I can't get a replacement seal too easily so would it be okay to get some gasket paper from an autoparts store and cut it to size or have you to use a special gasket?
Thanks.
Old Sep 17, 2004 | 05:47 AM
ede's Avatar
ede
lot of people use RTV and no gasket
Old Sep 17, 2004 | 05:52 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
I just changed mine
I just changed my rear axle gear oil and I never use the gaskets. I use permatex blue rtv silicone sealant. It has never let me down. Hope this helps.
Old Sep 17, 2004 | 07:21 AM
IrocZGrl88's Avatar
Car: 88 Iroc Vert
The limited slip additive is required for posi rears...it's an anti-friction fluid.
Old Sep 17, 2004 | 01:14 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I've changed both my rear end and tranny oils a few times. I probably should do it more frequently. I use 100% synthetic oils in them these days. Mobil 1, Redline, Royal Purple.
I have a 9-bolt rear end in my car, and I just use the synthetic lube in there with no additive. The LS additive is already built into the synthetic oils.
I too have used no gasket, just RTV, but I prefer using the gasket and RTV. No leaks.
Using the synthetics gives me some extra margin for being sloppy in not getting around to change the oil that frequently.
Old Sep 17, 2004 | 05:40 PM
rear axle oil
The gasket works best with Permatex Tack & Seal gasket sealer applied to both sides of the gasket. Mine doesn't leak at all.
As far as a gasket goes, I bet you could by one over the internet from numerous online parts suppliers.
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
Navy8125
Aug 21, 2015 09:32 AM
