chevy 350 interfreance engien??
Old Sep 16, 2004 | 09:05 AM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
ok well as in the distributor clamp problames it keeps truning. and i thinki got so bad that it F'd something up.i dunno though cause my ca wont start it starts sputting if i get it started and it sputters over 3000rpms it sputters and jolts and crap. got to school this morning. and i twas like being really gay. but. could my timing chain broke and now i f'd me egnien up or did it flood it self
Old Sep 16, 2004 | 10:02 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
How about getting a timing light, and resetting the base timing, then clamping the distributor down?? Seems like a logical first step to me.
Old Sep 16, 2004 | 10:35 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
yep..if you stripped the dizzy hold down bold you need to tap it to a larger size...very important the dizzy no spin grashopper!!
Old Sep 16, 2004 | 10:47 AM
thirdgen88's Avatar
Car: 1995 Corvette
more specifically, it is very important that certain parts of the distributor spin independantly of the others..
Old Sep 16, 2004 | 12:26 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
That seems to be your issue. If the base timing is WAY off like it sounds like it might be, then you need to get that set, and get that bolt hole right...
Old Sep 16, 2004 | 12:29 PM
ljnowell's Avatar
Man, grow up and quit posting this high school garbage here.
As far as the timing. DO a on how to install the distributor right. Pull it, reinstall it, and then set your timing with a timing light. Your problem will more than likely go away. At least your problem with your car.
Old Sep 16, 2004 | 02:28 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Sounds to me like his school needs some help, they're clearly not doing their job.
Anyway yeah, if your dist hold down bolt hole is stripped, you'll need to tap the manifold for a larger bolt. The dist must be clamped down firmly, not turn, and not pop up lest you lose drive to the oil pump.
Old Sep 16, 2004 | 02:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't tap your dist bolt hole to a larger size. The clamp won't accommodate anything larger than the OE size.
If the hole is damaged, Heli-Coil it, and use the right bolt.
From your description, you don't have an ignition timing problem, or a timing chain problem. Put the ignition timing back where it belongs, make sure both "fingers" of the clamp are on the dist body flange like they're supposed to be (which is more likely why your bolt won't tighten the dist, than the bolt hole being stripped), tighten it down, and leave it alone.
You have either a spark plug or a plug wire that's bad; or a fuel delivery problem.
I can't tell what you're asking about (I think this is what you mean) "interference engine". That term has nothing to do with the distributor.
Old Sep 16, 2004 | 03:28 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Go to the hardware store and get a big cork and put it in the dissy hole, and with the right size drill bit and heli coil, put some new threads in there. Then a stud.
After that put the dissy in and set the timing, tighten it down and your troubles are over.
Old Sep 16, 2004 | 05:14 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
wow i didn't know this ****ing board was such ***'s about shyt all the time. *** damn. i thought mayb thier was something else to it since i've tim3ed the car 4 TIMES NOW. no i'm not stupid about cars i was making sure. *** damn. some ppl just think thier high and mighty. any way i'm gonna buy a new clamp. as you called it a dizzy?? and what are good brands. or a good palce to find one. i also thought it could been my timing chain. cause i had a firend that morning turn the disrbuter to find a place were it owld start and noting and thats y i asked the question.
Old Sep 16, 2004 | 05:29 PM
ljnowell's Avatar
No one is being asses, just most of us dont like garbarge talk. No one here thinks they are high and mighty. BTW, to add to your knowledge of cars, a dizzy is a distributor. What they are implying is that you need a new hold down clamp for the distributor, either that or the bolt or hole is stripped to hold it down.
When you reinstalled the distributor, you followed the correct steps right? And no, I am not patronizing you, its just that 99.99999999999% of the problems with a distributor is because they are not installed properly. After that, how old are the plug wires? Plugs? Plug wires that are good, but old can go bad from a uninstall/reinstall. It happens.
Old Sep 16, 2004 | 05:36 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
i dudn't install the dizzy and i was justt advancing the stock timing by 4 then everything went worng so. i asked here. and i have just recently changed the plugs wires. thier about 40 miles old. i used bosh plat. i've herd good things so i thought i'd try them.
Old Sep 16, 2004 | 05:41 PM
ljnowell's Avatar
I dont think the bosch plugs are the problem, but IMO the best thing to use is the old AC delco plugs. Thats also the general consensus of everyone here. Do you have a timing light to use? If so, what is the base timing?
Old Sep 16, 2004 | 05:42 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'm a high and mighty smart-*** LJ!!
At least some people can read whatever the hell language your posting. I can speak three and can swear in seven, and I can't understand a word you're saying. Something about bosch platinum in the last post... are you running a spark box such as an MSD?
You might want to take the time and be a tad more clear and concise with regard to your problem as we have nothing other than your words with which we must use to attempt to diagnose your problem. See what I'm sayin'?
Old Sep 16, 2004 | 05:56 PM
ljnowell's Avatar
Yes, yes you are! But we can all be at times. Big agreement here though, if you dont fully explain everything, it wont help. Also, you say that you didnt install the Distributor, then maybe you should. Everytime me and my brother get someone in with a car that acts crappy like that, we check plugs and wires, cap and rotor. If all that checks out, out comes a timing light. If I dont have one, I will pull the #1 plug, go to TDC compression stroke, and restab the distributor and start over. Sometimes it will save a lot of time. Sometimes it wont. But if its been tinkered with, and you didnt install it, you should double check the other peoples work. What you dont know could kill you.
Old Sep 16, 2004 | 06:05 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I bet that you have the SP wires wrong. Check them, recheck them and then have somebody else check them. Then if that doesn't work get rid of the those crap plugs. There are many people on here that used those plugs and got the same results as you.
xkingcodex
Feb 12, 2020 07:43 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
theshackle
Aug 22, 2015 06:52 PM
