what type of 350 is it?
Old Sep 17, 2004 | 01:20 PM
NoUseAbleNames's Avatar
i went to go look at a 350 engine to pick up cheap and it looks to be out of some type of dump truck that he had parted out. it has a 1 barrel carb and mostly looks like a work motor so im guessing its 4 bolt. what does it mean on the valve cover it says
GM goodwrench MD 350
does this mean anything?? i
Old Sep 17, 2004 | 01:26 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
md = medium duty most likely
get the casting numbers off the block and post them or go to www.mortec.com and check them out there..
Old Sep 17, 2004 | 01:46 PM
ljnowell's Avatar
my guess is that it is an internal comustion 350. Just kidding. Actually, the carb thing is just like another thread on here. You cant tell anything by what is on the engine then. The one barrel carb could have been on any engine. With the valve covers, assuming they are original to the engine (which is a huge IF), it is probably a repalcement engine. Probably a smogged out low compression dog of an engine making 260hp with a four barrel, headers, and a lot of prayers, The one barrel carb is probably a carry over from the engine that was replaced.
Old Sep 17, 2004 | 03:19 PM
ok. im only paying 50$ so im probraly gonna get it anyway. it looks like its a pre emission era engine. but it might be caried over stuff. anyway im just hoping its a 4 bolt
Old Sep 17, 2004 | 03:25 PM
ljnowell's Avatar
#1, get the casting number. #2, pull the pan and check. However, the 4 bolt thing doesnt really matter that much for a street car. And if you are truly going all out, use a 2 bolt and go splayed, its stronger anyway.
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Billy Decker
Sep 4, 2015 03:46 PM
Formula_88AE
Sep 3, 2015 01:47 PM
